996 Turn signal issue
My 2000 996 C2's left turn signal (front and rear) is not working. The right side signals, high-beam lights, etc work fine.
Anyone think it is the turn signal relay instead of the switch itself?
Old 08-17-2016, 11:44 AM
Before you go any deeper- loosen the hazard switch on the dash and ensure that the connections are good and that the switch go on and off properly.
Old 08-17-2016, 02:56 PM
996 turn signal Issue
Everything works fine but the left turn signal. I will try a relay and if that doesn't do the trick then I guess the switch is my only other choice...
I had a similar issue on a 3.2 Carrera I owned and the switch was the culprit. That switch change was a bit more complicated than this appears to be on the 996, albeit for the air bag removal.
Thanks,
Old 08-19-2016, 10:00 AM
Administrator
Hey amazongreenie,
I found a tech article on our site that I think may help you further troubleshoot your turn signal issue. Let me know how it works out for you and best of luck!
Porsche 911 Turn Signal Tech. - Porsche 911 Carrera On Board Computer Turn Signal Installation - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
-Dmitry
Old 09-09-2016, 03:25 PM
