Headlights - low and hi beams not working
hello, I was hoping someone could help. I have a 996 2003. Recently the low beams stopped working and then I noticed that the high beams also don't turn on.
Low beams - I rotate the headlight switch - the parking lights come on, but when I rotate to next position (low beam position) the low beams do not come on.
High beams - I use the stalk lever to turn on high beams. Pushing it forward, it clicks into position, but the high beams do not come on. I pull it backwards (temporary position) and the high beams DO come on.
I checked the fuses and they are all okay. I checked the voltage at the fuse - for low beams, I do not see any voltage at the fuse when I turn the light switch on. For the high beams, I do not see any voltage at the fuse when I turn the stalk/lever to high beam position (but I do see voltage there when I pull the stalk/lever to the temporary high beam position).
I think it is the switch, but that would mean BOTH the headlight switch and the stalk/lever are bad?
I saw the message about cleaning/bending the stalk/lever switch to maybe fix the stalk/lever problem. Do I have to remove the steering wheel if I am just trying to clean the switch or can I get access without removing the steering wheel.
Thanks for any help you can give me
Old 08-21-2016, 04:19 PM
Replace the headlight switch. The flash position on the stalk bypasses the switch.
Old 08-23-2016, 06:24 AM
Administrator
Hey hughesra....FPB111 is absolutely correct. I've provided a link to one of our tech articles that'll help you do this. Please let us know how it goes and if you have anymore questions, feel free to post a Comment just below the article and someone will get back to you with some detailed tech info.
Best of luck!
Porsche 911 Carrera Headlamp Switch Replacement - Pelican Technical Article - Porsche 996-997 - Porsche 911 Carrera Headlamp Switch Replacement
-Dmitry
Old 09-09-2016, 03:19 PM
