Water pump
How to change out a water pump on a 997 S
Administrator
You might be able to use our 997 article as a reference for your S. Maybe some other Pelicans will chime in with the differences. Can also do a quick Google search and some other things will pop up for the 997 S. Water pumps here if needed: Porsche 997 (2005-2013) - Water Pumps.
Porsche 911 Carrera Water Pump and Thermostat Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article |
Porsche 911 Carrera S
When I did my water pump last spring, I also put in the low temp thermostat and new rubber hoses that were "touching" the things I was taking out. I'd also change out the coolant tank - I wish I had - mine developed age/stress cracks just a few short months after I did the water pump - I would have avoided some double work.
________________________________ John - 2005 C2S 997.1 at ~82k mi Last edited by OldSharp997; 12-25-2016 at 02:29 AM.. |
