Remove 996 Double DIN Stereo
I have a new-to-me 2002 C4S, but have been a long time pelican with my 944 Turbo.
My car came with a Pioneer touchscreen. I'm wondering how to remove it from the dash. I believe there are double DIN tools, but not sure how that would work here? Do I need levers to pull at the sides? PS - the reason for removing the stereo is that it is partially locked. Apparently it has a parking brake lockout to prevent use while driving, but that was not hooked up to the parking brake.
2002 C4S 105kmiles Boston MA |
a local stereo shop may have what you need.
on an older model I have it takes 2 flat bars 1/4 wide, 4 inch long and 1/10 in thick. find a slot on each side and slide them in about 3 inches. it should release spring tabs that pop into the side of the stereo. Does the screen remove from the faceplate? you may have to take it out to find the slots. good luck Lance
'99 Guard's Red C4 ; 2005 Cayenne Turbo, 09 Aston Martin V8 Vantage gone: W8 SW couple of Z-3 M's, couple of Lotus, Couple of MG's, Couple of Triumph's |
Thanks Lance. Took the dash surround off today, and that was the answer. Interior is in pieces, but I now have access to it.
Great
I hope your harness isn't as chopped up as mine. All those small wires are delicate
