R&R 996 coupe sunroof inside trim panel
Has anyone removed and replaced the inside trim panel on a 996 coupe sunroof?
My car came with the panel loose, and I do not have access to my Bentley manual. How difficult is it? Photos? Tips?
Thanks in advance.
Old 01-27-2017, 02:16 PM
Administrator
Check out this DIY tech article from our site on the 996 sunroof repair - it should give you some good info. If you have any other questions, feel free to Post a comment just below the article and someone will get back to you with more detailed info. Hope this helps and best of luck!
Porsche 911 Carrera Sunroof Repair
-Dmitry
Old 01-27-2017, 03:54 PM
Thank you Dmitry. The Pelican article was helpful in explaining how to slide the lining panel back to get at the sunroof bottom, but there is no discussion on removing the panel from the car, which is what I need to do. My liner panel has bent and broken mounting tabs and will not stay in place when the sunroof moves in and out.
Has anyone done this?
Is there any information in the Bentley manual on this? I have a Bentley, but its not nearby, so I need help with this.
Thanks in advance.
Old 01-30-2017, 08:00 AM
