Will996 (guest)
Guest
Posts: n/a
Might be a dumb question, I've only had to jack my 996 up a few times for work, I don't even jack it up for an oil change. With that said...other than giving more space, is there a reason to jack up the car, or would lightly jacking up the engine to lift it off the mounts work?
This post was auto-generated based upon a question asked on our tech article page here: Porsche 911 Carrera Engine Mount Replacement - 996 (1998-2005) - 997 (2005-2012) - Pelican Parts Technical Article
Old 03-21-2017, 10:09 AM
You'll need to support the engine from below since the engine hangs from the mounts.
- Casey
I did it without jacking up the car. Just use the jack to support the engine so it doesn't fall down as you remove the mounts.
Old 03-26-2017, 07:38 PM
