2007 GT3 997.1 torque specs 4 PCCB Brake Pad replacement
The 2007 GT3 PCCB front brakes instead of a cotter pin have a nut at the back end of the pin that holds the spring in place - does anyone know the torque spec?
(The nut is not visible below because is at the back side of the caliper) ![]() The rear brakes are different and require partial removal of the caliper, does anyone know the torque specs for the two bolts that I need to remove in order to replace the pads? (You can barely see the two bolts) ![]() Slightly better picture of one the bolts
Administrator
Hello - you may be able to find the torque specs online for the brake system, if not; you may have to find a workshop manual. They list all the torque specs and also having diagrams for all the fixes. I'm guessing other members may have this info for you. Best of luck!
Thank you Dmitry, unfortunately I wasn't able to find any information online, at the regular 997 workshop manual or Porsche online database. The main issue issue is that the GT3 is using different set up that the regular 911s. It also seems that the 996 GT3 has a different rear brake set up. In the Porsche online guide for some reason I couldn't find the info both times that I logged in for an hour session. If anyone has this info it would be great! Sent from my iPhone using Tapatalk |
I call Porsche dealership service departments for "vaulted" irritants like, perhaps, this torque spec and ask service dept. managers or technicians there until you learn it.
