garmo's Avatar
1980 911sc
Hey Porsche Peeps. The time has come to let go of my first Porsche, purchased almost 25 years ago. Following is a brief description of the car and it's history. I also have lots of parts. I would prefer a package deal, but might be open to selling off some of the parts independent of the car. Message me if you have any interest. $30k takes it all.
1980 911SC
Mileage – 85,007
On 7/24/92 this SC, Weissach Edition, experienced a fire. It burned primarily from the left rear corner to the right front corner, scorching wiring, plastic and rubber in the engine compartment and along the way. Bur for the plastics and rubber parts, the engine was undamaged and still runs very well. Unfortunately the insurance company totaled the car so it has a “Rebuilt from Salvage” title. I bought the car in December 1992.
It took several years to get the car running, mostly because of my limited free time. The car is stock but for SSI heat exchangers, a sport muffler and a Carerra oil cooler in the right front fender. The heat from the fire turned the tan leather to pink, so I dyed the leather interior gray. I replaced the carpet with a burgundy color and updated the wheels to turbo twist 17”.
The right, chrome headlight was damaged in the fire so I replaced both with painted trim.
Most of the undercoating burned off durding the fire. I ground off all the remaining undercoating that was bad, cleaned with laquor thinner what was still good, primed the underside, applied Wurth Undercoating, primed and painted the underside. That was a nasty job.
Odometer stopped working due to the fire at appx 73k. I purchased a working speedometer and noted the miles. I had the original speedometer repaired and recalibrated to 160mph. I feel the current mileage is within 500 miles of actual.
I have lots of receipts for most of my purchases, but not organized well.
I still have the stock muffler and HEs.
Tires are Yokohama S Drive in 205/45/17 and 255/40/17 – very good condition
Turbo twists wheels have a few scratches.
Newer, non-stock radio
I added sound deadening material to make it quieter.
Rear wheel bearings were replace about 600 miles ago.
What the car needs:
Tranny leak – one of the half shafts came loose while driving. I feel that is what caused the leak, but I have not addressed it other than to put on a new half shaft.
Downshifting into first – if going too fast it will grind. Common issue.
Front chin spoiler needs to be replaced.
Needs rear anti-roll bar.
Headliner needs to be installed. I have one, but the windows all need to come out to replace it and I have not had the time. The headliner on the sunroof is in.
Stock AC is out of car. I have the compressor buy have no idea if it is any good.
Right now there a problem with the fuel injection. Cars runs very strong and starts well. After warm up, it does not idle well, if at all. Car is drivable if you feather the throttle and brake with left foot.
For this car I have the following:
New window seals for all glass
Service manuals
Set of new lug nuts – one is missing, I think it is on the car.
New rear brake pads
Original temp gage – replace it with newer, numbered gage
Brake caliper kits NIB
Momo steering wheel and hub, but hub is wrong for the car. Was told it was the right one.
Headliner
Mahle oil filter
Fog lights are not on car. One has cracked lens
Misc fuses, clips, bushings, etc.
Stock muffler - original
Stock heat exchangers - original
Other things I have:
Very nice set of Weber IDA 40 Carbs
98 mm cylinders ready for a new motor
3.0l motor from 78 SC with appx 70k miles I bought off Pelican a few years ago – I have done nothing with this since I bought it
Hydraulic chain tensioner kit
Older 915 tranny – condition unknown
Spare set of door panels
2 Warm up regulators – One is new I think
15x7 and 15x8 fuchs – not great condition cosmetically, but straight
Garmo
'80 911SC
Old 07-08-2017, 03:11 PM
garmo's Avatar
Bump
Garmo
'80 911SC
Old 07-11-2017, 07:48 AM
garmo's Avatar
Sale pending
Garmo
'80 911SC
Old 07-12-2017, 07:01 AM
garmo's Avatar
UPDATE - Money is in the bank and my 911SC is headed to Amsterdam! Great transaction! RLX is a man of his word. Thanks Peter.
Garmo
'80 911SC
Old 07-17-2017, 12:13 PM
