1988 Porsche 944 Turbo LSD (FL) $7000
Located in St Augustine, FL.
For sale is my 1988 Porsche 944 Turbo with 127,000 miles. I've had this car for about 9 months now. I've driven it daily and put about 8,000 miles on it with no major issues. It has been a reliable daily. 1988 Porsche 944 Turbo Nautic Blue 127,000 miles Limited Slip Differential Linen and Black interior Modifications: Boxster Wheels with Good Continental Tires Lindsey Racing A-Tune Cat Delete 3 bar fuel pressure regulator Stage 8 Locking CV Bolts OEM Koni Shocks (front modified for inserts) AEM Wideband Boost Gauge Recently done: Timing Belt and Water Pump Motor Mounts CV Axles Ball Joints Brake Rotors and Pads Accessory Belts Spark Plugs Transmission Oil Hatch Pin Seats Lloyd Floor Mats Suede Dash Mat Main Issues: Oil Leak from either Rear Main Seal or Oil Pan (add a quart every 2,000 miles or so) Power steering fluid seems to weep out of reservoir AC Compressor seems to be leaking (doesn't hold a charge) Sunroof needs new lift arm covers and perhaps one of the relays needs to be replaced (it won't raise to the tilted open position via switch, but every other function works) Car has single accident history; apparently hit a fence. Front bumper cover has some cracks. Most panels have been repainted and the repaint is very poor. Looks okay from 15 feet away. Car has damage to the driver's rear quarter (dented in and chipped paint) The interior has a few minor issues but overall is in great shape. If you want a car with a solid drivetrain and a good interior, look no further. A little bit of work and a repaint and you'd have a great car. Asking $7000 PM me if you want to talk. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]()
Bump. Shoot me an offer.
Bump. Price drop. This is a great deal.
| Tags |
| 944 , 944 turbo , lsd , porsche |
