mca mca is offline
mca's Avatar
1979 911sc
1979 911SC Sunroof Coupe - Red / Black
119,600 miles
Charleston, SC
$27k
Time to sell my 1979 911SC. I’ve owned this car for 4 years - my father owned it for 6 years prior. This car started it’s life with a brown exterior and tan interior. At some point it was painted red by the previous owner (not sure of exactly color code) and my father updated the interior to full black. The car runs and drives as a 911 should. It gets an insane amount of attention.
Details
SSIs with Dansk sport muffler
New clutch and flywheel seal
Backdated heat
Valvoline VR-1 20/50 Racing Oil
H4s (have original sugar scoops)
Professionally lowered, aligned, and corner balanced
6x16 Fuchs up front and 8x16 Fuchs in back
Oil always changed at 3k and valves adjusted every 12k
Wevo Precision Shift Joint Coupler
Pop-off Valve
New antennae
Silicone valve cover gaskets
New driver’s seat belt
Engine removed, cleaned, and ‘triangle of death’ leaks were addressed
Leaks a few drops. After addressing the triangle of death leaks on top of the engine and the rear main seal, I suspect that the leak is from the engine oil cooler.
Only non-ethanol gas
Always garaged
Interior is 8/10
Issues
No A/C (subjective ‘bad’).
Car was repainted by previous owner. It is in decent condition with some flaws.
Body has a couple of dings here and there - two at corners of front hood
Dash is in OK shape.
Seems that a caliper is going but haven't put it in the air to determine which one.
82 911SC Coupe Chiffon / Chocolate
9.5 JEs, 964 Cams, SSIs, Dansk Exhaust, CIS (SOLD)
Last edited by mca; 08-20-2017 at 07:46 AM.. Reason: Mileage error from 116,900 to 119,600
Old 07-29-2017, 05:20 PM
mca mca is offline
mca's Avatar
Thank you for all of the interest! Here are some interior pictures.
Old 07-30-2017, 11:53 AM
mca mca is offline
mca's Avatar
Thanks for all of the interest! I believe that I have responded to all PMs, texts, and phone calls. Currently there are several offers on the table and a list of interested buyers. I'm trying to work through them in a methodical, fair manner. Thanks for your patience.
https://www.youtube.com/watch?v=h7sjJeiODaQ
Old 08-01-2017, 03:50 PM
mca mca is offline
mca's Avatar
Sold! Thank you for all of the interest!
Old 08-03-2017, 09:06 AM
