Six Pin connector in engine bay
I have been rebuilding a 99 911 C2 Cab that had an engine fire I had to repair the rear body harness and most of the sensors. I am left with a connector off the rear body harness. When I went to the wiring diagram for the 996 it refers to it as the automated exhaust gas recirculation examination
This connector comes off the pigtail that passes through the bulkhead. I just don't have a place to plug this connector into. Can anyone help me identify this? and what it plugs into.
Bill
Old 08-01-2017, 08:42 AM
Try reading the Porsche part number (996-----) of this connector, if you can find it, Then put that number into the Pelican search function and see what comes up.
2015 Porsche Macan S, Dark Blue Metallic
2011 BMW 328xi, Crimson Red
Old 08-01-2017, 12:03 PM
I looked for a 996 part number but there is not one on it.
I don't think I mentioned that it's on the right hand side (passenger) near the two circular main engine connectors that connect to the engine harness.
Old 08-01-2017, 05:44 PM
I figured it out it is a test port and does not need to be plugged into anything.
Old 08-02-2017, 12:28 PM
Sorry, I can't help you much. I checked PET, but I could not find that part. My 2003 C2 coupe seems to have a similar connector that is plugged into a black connector block just to the right of the right side motor mount. It seems to be related to the right rear lighting, but I cannot be sure. Six connector points, but only three wires used.
Old 08-02-2017, 05:39 PM
