J_M J_M is offline
Unhappy 996 electrical gremling
My 996 developed a problem. Nothing happens when turning ignition key, no lights on dash. Replaced ignition lock electrical part. Battery OK. Radio, interior lights, hazards works, immobilizer blinks.
Master fuses / relays to check. Fuses on foot well compartment are OK. All ideas welcome ...
- 1997 328i
- 1966 289 C4
Old 11-19-2017, 02:03 PM
Dead switch at clutch pedal ?
Old 11-19-2017, 02:57 PM
J_M J_M is offline
Doesn't it just block starting without pressing clutch pedal? There's no dash lights or anything ...
- 1997 328i
- 1966 289 C4
Old 11-19-2017, 03:29 PM
I was replacing the amp today on my 99 Carrera and as I removed the battery I found a lot white discharge and rust in the battery tray. I followed the positive terminal to the wall and found a lot of trash as well as the positive terminal the same whitish discharge on the end of the terminal .Once I cleaned it the lights in the dashboard came on brighter. I would check the terminal. Hope this helps.
Tpstatic
Old 11-19-2017, 04:49 PM
J_M J_M is offline
Mine is completely clean but will check the terminals tomorrow. Thanks for the tip ...
- 1997 328i
- 1966 289 C4
Old 11-19-2017, 06:33 PM
Uncertifiable!!!
Uwon's Avatar
Common issue. Try pulling the key out completely, then shake wheel left-right several times then reinsert and try again. I find that parking with side pressure on the steering wheel lock or tires will exacerbate the problem, so I just do the “shake” routine.
Johan
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 11-20-2017, 06:21 AM
J_M J_M is offline
Tried, no effect. Mine has newer version steering lock assembly ...
- 1997 328i
- 1966 289 C4
Old 11-20-2017, 12:21 PM
