2001 996 turbo
noticed a prominate coolant leak on the front passenger side of car just in front of front right tire? would appreciate any info on the probem and fix. thanks to all in advance
Obviously the right rad is there as well as inlet and return hoses. You’ll have to pull the inner fender well to explore and maybe the bumper cover.
thanks. it only has 29k. hopefully its just one of the hoses
Yes, but it is also 17 years old. Rubber deteriorates whether it is used or not.
yes your 100% correct. thanks again for your reply
oops. im very inept at using modern day technology. im attempting to remove the front bumper on my 2001 996 turbo. ive removed all screws and attachments that ive followed online. my issue now is attempting to loosen the inner plastic wheel well cover? ive removed the fastners, but cant get the inner cover loosened. seems to be snugly embedded in the fender as pictured. need help with any suggestions? ive thought about trying some lubricant or possibly a hair dryer to heat the rubber/ molded plasic??? thanks to all in advance
