Gearbox atf oil
2004 Porsche 996 c4s
Am i right in thinking when i change the tiptronic gearbox atf oil that the atf oil should be RED in colour .Just that when i saw them change an automatic gearbox on a 986 Boxster on Wheeler s Dealers it was a clear colour.
Old 04-26-2018, 08:37 AM
ATF color is dye, so you can make it just about any color you want, or no color at all.....
Old 04-26-2018, 08:54 AM
Ok Thanks.So as long as i put ATF oil in it i will be ok
Old 04-26-2018, 09:27 AM
Not quite, you need an ATF that meets the specs for your transmission; not all ATF's are the same, and using the wrong one can kill the gear box.
Old 04-26-2018, 09:29 AM
Hi
Do you knot the spec as all it say in hand book is 9 litres of atf.Thanks
Old 04-26-2018, 09:43 AM
Model and year of the car?
Old 04-26-2018, 11:40 AM
2005 porsche 996 c4s
Old 04-26-2018, 11:45 AM
Tiptronic Transmission Part Number 999.917.547.00 Automatic transmission fluid (20 liter container).
Old 04-27-2018, 06:23 AM
I have decided i am just going to top it up to the right level for now,
Can you mix ATF oil,as not sure whats in there
.like if it clear in there and i put red in ,or other way round
Old 04-28-2018, 03:44 AM
Hi ANY ONE ?
Old 04-30-2018, 09:53 AM
If it is at 60k miles, change the Tipt fluid.
Old 05-02-2018, 03:45 PM
