Go Back   Pelican Parts Forums > European Car Forums > Volvo Technical Forum
Loose mount?
Hi All,
When recently getting my oil change and tires rotated, I was told that the crossbar that holds the engine up (mount?) needs to be replaced.
This makes sense because as I drive around I hear a jiggling noise in the hood of the car and squeaking, as if something is loose (especially when I hit bumps).
Is it called the engine mount? And how prevalent is it that i get it fixed ASAP? Money is tight.
Thanks ALL!
Pete
Old 01-12-2011, 01:45 PM
Author of "101 Projects"
Wayne 962's Avatar
Yes, this is the engine mount. You should be able to purchase the mount (here at Pelican), and then jack the car up on jack stands, raise the engine with the jack, and replace the mount...
-Wayne
Old 01-22-2011, 02:09 AM
