-   VW/Audi Technical Forum (http://forums.pelicanparts.com/forumdisplay.php?f=264)
-   -   Why do they use plastic for chain tensioners? (http://forums.pelicanparts.com/showthread.php?t=942048)
sugarwood 01-10-2017 03:06 PM
Everyone has seen this scary Audi V8 photo.
It seems like this is not just Audi, but most car makers.
Are you simply unable to use metal on metal?
Are the plastic guides a sort of the sacrificial layer, albeit one that lasts 100k?
http://i.imgur.com/t5XUfav.jpg
https://www.reddit.com/r/pics/comments/3fm4t7/inside_an_audi_b6_42l_v8_engine/
The previous Audi S4, which came out in 1999, used a timing belt rather than a timing chain. This annoyed the hell out of everyone, because the belt had to be changed every few years, and the only way you can do this job, or any job in a 1990s Audi, is you have to remove the front end, and the engine, and all the glass, and then you have to do a little jig on the service drive that involves a socket wrench and some lederhosen. For this, you may bill 31 hours.
So what Audi did on the V8-powered S4 model, which came out in 2004, was obvious: they ditched the stupid belt for a chain, like most other automakers. And since the chain was now designed to last the life of the car, Audi decided to stick it waaaay in the back of the engine, up against the firewall. Apparently the theory was that the chain would be so robust, and strong, and dependable, that it would never have to be serviced. You can probably guess what happened next.
Yes, that's right: it had to be serviced.
You see, as it turns out, the chain itself didn't have any problems with dependability. But Audi, being Audi, decided to use substandard materials for the chain tensioners, and the cam adjusters, which are two related – and highly important – components that keep the chain turning around and around and around every time you drive the car. The result is that these parts eventually fail, requiring the replacement of virtually everything you see in this amazing image of an Audi S4 engine worryingly sitting outside an Audi S4
Here’s Why The V8 Audi S4 Is An Awful Used Car
DRACO A5OG 01-10-2017 03:11 PM
From my experience every car I hacked on had plastic type chain guides, I am guessing better to have plastic residue vs metal???
Redbarnman 01-10-2017 03:26 PM
These are pretty specialised plastics used to keep full control over the chain (prevent any lashing about) and be quiet in the process. As the other post says it's also better to have a few bits of plastic dust in the oil over metal swarf. I believe the chain rollers should run on the plastic rather than the chain side plates - I have seen badly worn plastic chain guides when the wrong spec chain was used. Fords have used a small block of rubber as the wear surface on the end of a chain tensioner and they last well if the chain has ground side plates
Kraftwerk 01-10-2017 03:36 PM
Frangible stuff should be easier to service, like on my 911sc ..it's all right there easy to access those plastic 'ramps'
famoroso 01-22-2017 05:44 PM
I own four cars. All with timing chains.
What's going on in the background of that picture? The world's biggest micrometer?!
