aux fan help
New to bmw's and could use a little help. How hard is the aux fan in front of the radiator to change and what is involed to do it.
Thanks,
Grady
Old 04-04-2003, 12:29 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Ok what year and model car do you have?
Old 04-04-2003, 12:30 PM
1989 325i conv sorry I forget.
Old 04-04-2003, 12:31 PM
auto or manual tranny? Why do you needf to change out the fan? This fan is usually only used when the A/C is on.
Old 04-04-2003, 12:33 PM
manual trans the a/c does not work and I am going to get it fixed and the a/c shop said the fan has to work and it is froze.
Thanks for your help
Old 04-04-2003, 12:35 PM
I believe you will need to remove the three front grille pieces and the hood. Then you simply unbolt it from the front of the condenser.
Are the fan bearings shot?
Old 04-04-2003, 12:39 PM
Yes I thiks so I have not got it out to see. I have a parts car to get one out of.
Old 04-04-2003, 12:41 PM
Before you remove it, you might want to try spraying some WD-40 in there and apply 12V to the fan. See if that gets it spinning.
Old 04-04-2003, 12:42 PM
