Check engine light
Hey I got a sittuation on my hands & looking for any advice on what the problem might be. I just bought a '99 M3 w/ 47k miles and just this evening just cruising around running some errands and after pulling out of the drive-thru I sort of stomped on the throttle to experience some bavarian blast and the check engine light comes on about a mile later and wondering what might be the root cause of this. I read in the BMW 3 series guide by Jeremy Walton that all E36 cars in general have engine management self diagnostics and continues to say that on '92-'95 cars, quickly flooring the the accelerator 5 times will initiate a fault read out and also wonder if anybody has had this problem on their E-36 M3's.
Bimmerdog
1999 BMW M3 Coupe w/ 18"Breytons
1994 Toyota Corolla (winter/work)
1991 BMW 318is (in a dismantled state)
1990 VW JETTA Coupe (soon to be sold)
Old 04-03-2003, 07:51 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
when you say blast, do you mean something sounded like something blew up?
Old 04-04-2003, 10:26 AM
No. actually what I meant by blast is rapid acceleration. There wasnt any noise or anything out of the ordinary. I just basically got on the throttle & about a mile later check engine light is on. And still is. I bought the car w/ the CPO warranty frm BMW but was just curious as to what may have caused this. I'm sure there could be a plethora of reasons.
Bimmerdog
Old 04-04-2003, 11:32 AM
Hmmm i dont know what to tell you. I would try doing the code thing and see what it tells you. I have a guide for the codes if that helps. You know how to do it? i have a tech article i can send that goes over how to do it.
Old 04-04-2003, 12:52 PM
No I dont know how its done so if you can send it over, that would be much appreciated!!
Bimmerdog
Old 04-04-2003, 02:46 PM
send me your email address
Old 04-04-2003, 02:48 PM
okay. will do
Bimmerdog
Old 04-04-2003, 03:08 PM
article sent..
Old 04-04-2003, 03:09 PM
bimmerdog23@yahoo.com
Bimmerdog
Got it. Thanks again Jared
Bimmerdog
Old 04-04-2003, 03:15 PM
notoriousM3's Avatar
Send a message via ICQ to notoriousM3
I'd be willing to bet its one of two things. First make sure the gas cap is on properly. Second it may be an oxygen sensor gone bad.
Old 04-19-2003, 08:30 AM
You are exactly right on the second one. It's an oxygen sensor. How many oxygen sensors do I have?
Bimmerdog
Old 04-20-2003, 09:51 AM
I believe there are 7 and they are usually covered under warranty
Old 04-20-2003, 11:27 AM
