nut nut is offline
help ......clock dead
hey guys,
my brother's clock is now dead, and is it a bulb or isit LED, LCD?
i will attempt to fix this if it is a bulb, otherwise , does anyone know of this problem?
Old 04-28-2003, 11:27 PM
stupenal's Avatar
Its most likely the bulb, its a really easy fix. The bulb cost $3.50 at my stealership, it may be available at radio shack or something. My method of removing the OBC is different from some, but I find it easier.
To remove the OBC, take either a flat head screw driver or an old credit card of some sort. Insert the flat object into the crevice surrouding the OBC and gently try to push the obc out. Eventually, you'll be able to remove it by constantly pushing at all sides. On the top you'll see the 4 different bulbs, 3 for the display, 1 for the clock. Using the flat head screwdriver, turn the bulb 180 degrees (not sure either clockwise or counter, shouldnt be too hard to figure out) and it'll pop out. Replace it and slowly push back the OBC. I think this topic has been covered, do a search and you'll find the original thread. Have fun, its an easy fix.
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 04-29-2003, 10:40 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Very easy to fix. Just do what stupe says and you will be stylin
Old 04-29-2003, 11:19 AM
nut nut is offline
thank you
thanks guys, i will let bro read this, much appreciated
Old 04-29-2003, 12:06 PM
I had the same problem. I posted a thread on this earler.
pull the computer dash out (there's a notch underneath to trigger). You'll see four bulbs (12v, 1.2w I believe) in a horizontal row. I though it was a 90 degree counterclockwise turn to remove (maybe I'm mistaken). You can do it with your fingers, no need for a screwdriver (on my 95 325i anyway).
I didn't get around to buying a new bulb, so what I did was swap the clock bulb(bad one) with the good bulb to the left of it. THe display works fine, and is only slightly dimmed on the right hand side - if a long message displays.
It's an interim solution until you can get a new bulb.
Old 04-29-2003, 12:53 PM
stupenal's Avatar
Champeny, I did the exact same thing. The dealer gave me a non functional bulb, so i said screw it and just took the one from the side and put it in. I mean, i rarely ever use the OBC anyways, the clock is much more important. I crashed into the car in front one time while I was trying to get out my phone to check the time. Thank goodness it was really slow and no damage at all. But it sure scared me!
Old 04-29-2003, 01:51 PM
Im not sure of the actual wattage for the bulb, but i know you can get them at any local Fry's or Radio Shack.
Old 04-29-2003, 04:27 PM
