Anyone know the size
Anyone know the size of the bolt on the crankshaft. When I changed my timing belt I recall not having the right size ratchet, and now that I am lining up to adjust my valves, I want to make sure I have the right one (to rotate the engine to TDC), before I jack it up and start.
Thanks.
Old 05-19-2003, 01:00 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I believe it is a 32mm.
Old 05-19-2003, 01:29 PM
Size doesn't matter! It's staying power that matters! Speaking about the E30 of course. . . .
87 'bertible
Old 05-20-2003, 06:17 PM
do it the easy way jack up the rear of the car stick it in gear and rotate the tire to get to the right valve to adjust
Old 06-12-2003, 09:29 AM
Stick it in fifth gear..
Old 06-12-2003, 10:10 AM
I've got an auto... does that preclude the tire adjust... (sorry Jarred I think I hit you on this one on an email... still haven't done the job)
Old 06-12-2003, 11:17 AM
hmm. I would just turn the front nut on the crankshaft then...
Old 06-12-2003, 11:50 AM
Sorry I think that is what you said the first time, which is why I then focused on the crank... trying to do 10 things at once, and not having time to complete any is not the way to go...
I should make a list.
Old 06-12-2003, 11:54 AM
