Broken Threads on Shock Tower
I made a critical mistake thinking that my torque wrench was set to the proper setting and I found out that I over torqued my bolts on top of the shock mounts. One bolt snapped and the other one won't tighten. How much will this cost to fix? How do I fix it? What part do I buy? I assume that the springs have to be compressed and since the 98 m3 has 56k, then I might as well replace the shocks. Maybe I should buy a spring shock package and upgrade my suspension. Any thoughts as to which package to buy? Any help would be appreciated. I don't want a kidney busting ride, but I would like a bit stiffer suspension than stock.
This is on the front of the car, not the rear. Maybe I am using the wrong words - shock tower. There are three nuts holding the shocks to the body of the car. |
Senior Advisor
Are these the 3 nuts on top throught the engine comp? if so then you can just replace those mounts with out haveing to re-do the suspension.
The center nut (big one) thats the strut. call me if you have any questions on this.. 1-888-280-7799 xt 239 or e-mail javier@pelicanparts.com
...96 Chevy heavily Modded such items include... lil' pine tree air freshner.... duct tape rht front arm rest (i'ts falling) zip tie holding in rear tail light.... hi concentrate windsheild washer fluid... sticker of Speedy Gonzales..rear bumper... |
