no spark on #2 cyl.
I am not getting any spark on the #2 cyl. Iknow nothing about dist.,I have never had a problem with this on any car I have ever owned. Any tips or suggestions?
Old 06-16-2003, 10:08 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Might help if I knew what kind of car you have.
Old 06-16-2003, 10:14 AM
Sorry. It is a 85 318. Also noticed that where the roter sparks on the other cyl. it is barley hitting it. If this was off any more all of them wouldn't fire.
Old 06-16-2003, 10:18 AM
Ok, have you checked the following
1. Spark plugs, pull them out and see if the no. 2 is fouled
2. What is the condition of the rotor? Is the faced burned or pitted?
3. How is the condition of the inside of the cap? Cracks, pitting? Anything?
4. Have you checked the spark plug wires? One (or more) may have built up internal resistance and cuased it to no longer transmit spark.
There may also be the possibilty that you have a mechanical fault with the distributor itself. Ont hese cars, they use a hall-type four prong plate that acts like a firing guide. (basically it replaces mechanical points with a optical or magnetic sensor. I have seen a few of these need a slight adjustment to fix a dead cylinder, however i would check the things up top first.
Im betting you have a bad plug wire. What you can do is replace the plug wire going to the number two cylinder with a known good one and see if the plug fires.
Old 06-16-2003, 10:25 AM
The problem is in the dist. All other things mentoined are new.On the cap there is no sing of it sparking. All others show a sing of aspark.
Old 06-16-2003, 10:30 AM
Ok, did you try replacing the wire yet? Understnad that the cap has no moving parts, it's just a few contact strips inside. Look inside and check the terminals on the inside of the cap Do they look corroded? pitted? Burned? Keep in mind that when you get a new cap, those contacts should look like freshly cleaned brass.
Old 06-16-2003, 10:32 AM
The wires are brand new. Yes all the contact strips are shiny.Iwas having this problem before they were replaced.
Old 06-16-2003, 10:38 AM
The #2 is shinier then the other ones, no spark.
Old 06-16-2003, 10:41 AM
Ok, pull the cap off, pull the rotor off, and the small plastic disc underneath.
Once off you should see a 4 pronged cross. This is the armature for the ignition. Inspect it, does it appear bent or damaged?
Old 06-16-2003, 10:43 AM
No they look straight. Were the spark is hitting the roter is on the very back edge if this was off any more none would spark.
Old 06-16-2003, 10:48 AM
Hmmm. Have you pulled the plugs?
Old 06-16-2003, 10:49 AM
No I haven,t pulled the plugs I just put them in.
Old 06-16-2003, 10:51 AM
They have about 10min. of running time on them.
Old 06-16-2003, 10:52 AM
What KIND of plugs?
Old 06-16-2003, 11:01 AM
Boshe.The standered ones not the platinum. Iwas having the same problem before I replaced all this. I too thought it was a bad plug wire but this is the second new set on there.
Old 06-16-2003, 11:05 AM
The cap and roter are boshe as well. Agian the second new set that hasn't worked
Old 06-16-2003, 11:06 AM
Hmm... this is puzzling, because typically, if there was a problem, ALL the plugs would cease firing, not just one..
I assume you have checked the wire for spark (like with a screwdriver against the block) and there is no spark, right? But the other ones fire?
Maybe something with the dist. advance is causing this?
Old 06-16-2003, 11:08 AM
I'm pretty sure it is something with the dist. advance but this is an area that I have no knowledge of.
Old 06-16-2003, 11:10 AM
The guy who owned the car before me did some strange things with the wireing.
Old 06-16-2003, 11:11 AM
Hmm... can you tell me what sort of advance you have on there? There were a coouple different ones over the years. If im thinking correctly, on yours there should be one vacuum hose and an electrical connector going to the distributor.
Old 06-16-2003, 11:14 AM
