| Clay.0 |
06-24-2003 11:15 AM |
another window problem!!
ok, so my driver side window doesn't work. seems like a common problem with a solution that i have not yet found. the passenger side works great. i've switched the bottons and they both work great on the passenger side so i know they work. i took the door panel off the driver side and tested for power and nothing. then i hooked up the battery and the motor worked fine. so then i thought it must be something between the switch and the motor. i followed the wires from the switches to a box behind the glove box, (this box clicks when i hit the switch) Is this box the problem? any suggesting or help at all would be great!:confused:
