Question brake light circuit
1997 M3 with on board computer....periodic flashing "brake light circuit or brake circuit light"??? any suggestions?
also looking for an owners manual..
Old 06-17-2003, 06:49 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
have you checked your brake lights? Have you replaced them? I need more info here...
Old 06-18-2003, 08:29 AM
adamnitti's Avatar
Send a message via AIM to adamnitti
yup. it's your brake light switch... very common failure item. pick it up at the dealer. i think it's about $25 max...
the switch is located under the dash above the brake pedal. here's a link for ya for the fix:
http://www.bimmerzone.com/brakelight.htm
change it and all will be better.
Adam Nitti
www.adamnitti.com
...In search of the next 911...
Old 06-20-2003, 10:11 AM
This couls also be a loose brake light bulb. I've seen people just wiglle the bulbs and suddenly everything works again.
Old 06-20-2003, 10:12 AM
umnitza's Avatar
Send a message via Yahoo to umnitza
9 out of 10 times it's the brake light circuit switch. it's under your pedal - well actually around the pedal arm
| BMW Enthusiast | BMW Owner | umnitza@pacbell.net | www.umnitza.com |
Old 06-21-2003, 08:58 AM
id say 9.9 out of 10
74-1.8 (sold)
86-944 turbo (sold)
97-M3 coupe (sold)
03-M3
http://www.pelicanparts.com/gallery/castlesteve/
Old 07-18-2003, 06:54 AM
