supertack's Avatar
BMW Rotors
I gotta get my front brakes done, sensor pad light came on & well, I'm at 61k miles and on the original rotors. So in a contrasting forum, why are the BMW factory rotors softer than American replacements? I'm thinkin about ditchin the BMW part & puttin on something a little harder, like a Raybestos rotor.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 08-17-2003, 06:34 AM
supertack's Avatar
Nobody's got an opinion on this?
97 328is
Old 08-22-2003, 04:38 AM
dsonyay's Avatar
Raybestos is a good company. I can't see the problem with buying their rotors/pads if there's an application for your E36.
Only problem, the stopping power may not be as good as BMW rotors/pads. I'm thinking that "if" BMW rotors are softer, then it may be part of the reason why their cars stop so well. I'm not an expert at that, but seems plausible- kinda like the R compound tires: They have superior grip/soft tread, but at the sacrifice of long wear. ??
If you do get Raybestos, please let us knopw what you think.
Old 08-22-2003, 06:44 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Here's my opinion. It's a German car, use German parts..
Raybestos, ok.........
Old 08-22-2003, 09:10 AM
supertack's Avatar
So you wouldn't do any repairs/modifications with anything other than a German part? Is that realistic? I mean, you've recommended Yokohoma tires in the past, they aint exactly German.
97 328is
Old 08-22-2003, 09:51 AM
In my opinion, yes, i would never use anything except OE German parts. Especially when it comes to brakes. I really believe that US built components are quite inferior to most German stuff.
Old 08-22-2003, 01:09 PM
BIG SHATTUCK's Avatar
Stick with BMW unless you want to upgrade to drilled or slotted. Rotors for that car aren't more that $70 a piece.
Old 08-25-2003, 01:58 PM
I have to take the attitude that there's a reason the brake rotors were manufactured out of a softer alloy, if that is the case. Time after time, I have continued to be amazed at the level of engineering i9n these cars, and I have come to appreciate and accept that this is the way these cars were meant to work.
Old 08-25-2003, 03:32 PM
My wife's car runs Hawk race pads on stock rotors (this is basically a track car). After 3 track days there is no brake fade there is very little wear on the rotors. The pads are starting to "chip" away a bit on the leading edge though. She buys the rotors through Bimmerworld for about $ 30.00 each.
Keith
74 914 2.0 (sold)
96 328is
Old 08-26-2003, 09:56 PM
