Power Window PRoblem
My passenger side window is not working correctly, it will only go down about 1 inch at a time and when the door is open in will not go down at all.
Has this happened to anyone else and why is it happening? |
have you checked the motor? sounds like a faulty motor to me
I would also suspect the comfort relay as well.
I have the same proble in a 318 is and will be working on it this the next couple of days I will let you know what will fix it.
thanks
sounds like it does need a window motor (most likely) but there are other possibilities. Check the connector in the door jamb. Most likely though, the motor is bad.
It's easy fix and cheap, no need to waste your money by replacing your motor or anything like that. It's just a loose magnet on the motor shaft:
here it is: http://bimmer.roadfly.org/bmw/forums/e36/forum.php?postid=1747458&page=1 |
thanks a lot i will try this very soon, it seems like it will work
I have a similar problem with my driver's side window. If in fact it ends up being that a loose magnet needs to be replaced on the motor shaft, then how does one go about doing this.? And what is the part number for this particular magnet?
| All times are GMT -8. The time now is 03:48 PM. |
