jbush's Avatar
Send a message via AIM to jbush
Power Window PRoblem
My passenger side window is not working correctly, it will only go down about 1 inch at a time and when the door is open in will not go down at all.
Has this happened to anyone else and why is it happening?
92 325IS
Black on Tan 5 Speed
Old 08-27-2003, 11:46 AM
stupenal's Avatar
have you checked the motor? sounds like a faulty motor to me
1997 M3 Sedan 5spd Artic Silver/Dove
M3 Bumpers/Mirrors/Sideskirts
S52 3.2L, M3 Wheels, M3 suspension, M3 Brakes
Oh wait...it's a stock M3
Old 08-27-2003, 11:37 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I would also suspect the comfort relay as well.
Old 08-28-2003, 11:26 AM
I have the same proble in a 318 is and will be working on it this the next couple of days I will let you know what will fix it.
Old 08-28-2003, 02:25 PM
jbush's Avatar
thanks
92 325IS
Old 08-28-2003, 07:22 PM
EXtech's Avatar
sounds like it does need a window motor (most likely) but there are other possibilities. Check the connector in the door jamb. Most likely though, the motor is bad.
Anyone in Texas or Louisiana needing a MORTGAGE LOAN, email me!!
Old 08-28-2003, 10:19 PM
eren's Avatar
It's easy fix and cheap, no need to waste your money by replacing your motor or anything like that. It's just a loose magnet on the motor shaft:
here it is:
http://bimmer.roadfly.org/bmw/forums/e36/forum.php?postid=1747458&page=1
Old 08-30-2003, 09:07 PM
jbush's Avatar
thanks a lot i will try this very soon, it seems like it will work
92 325IS
Old 08-31-2003, 09:04 AM
I have a similar problem with my driver's side window. If in fact it ends up being that a loose magnet needs to be replaced on the motor shaft, then how does one go about doing this.? And what is the part number for this particular magnet?
Old 07-13-2004, 12:23 PM
