Question Fuel door problems (325 convertible)
My gas door flops around. I was told that it should lock closed but it is not working. I have only had the car a month so I'm not sure how it is supposed to lock shut.
The locking mechanism inside the gas door area is in the open/unlock position and doesn't seem to move.
I would prefer to fix the problem rather than put velcro or a magnet on the fuel door.
If you have any tips or advice It would be greatly appreciated.
Thanks, Joel
95 325ic
92 Turbo Mazda Sport truck
89 Supercharged Mustang
Old 10-12-2003, 01:43 PM
914 Geek
It locks when you lock the doors. Took me a while to figure that one out, too... There's an emergency release inside the trunk, underneath the felt stuff that covers the right side of the trunk.
--DD
Old 10-12-2003, 05:43 PM
Registered Nut
Drews323i's Avatar
The spring that holds it closed may be broken. Should put up some effort when opening. When the spring breaks, door flops around.
1980 323i
1994 325i
Drew
Old 10-13-2003, 05:13 AM
Thanks Dave & Drew for the tips and suggestions.
I tried the "double lock" thing and it seems that the mechanism isnt working. I found the emergency release as suggested and it seems there is a problem with the mechanism itself, there is no tension on the pull. BTW- thanks, I didn't know that was there!
I'm going to get a better look by pulling the trunk liner out of the way so I can gain access to the latch and I'll let you guys know what I find, thanks for the help!
Joel
95 325ic
Old 10-13-2003, 01:34 PM
