Send a message via AIM to autopasse
light burned out on '88 325is OBC
The light has burned out that illuminates my on-board computer on the c-stack of my 325is. The functions are still there, but it's very faint. What do I need to replace so I can see the time/range/outside temp?
Old 10-26-2003, 07:01 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
You need to remove the OBC, and change out the bulb. Are yuou talking about the orange display or the buttons themselves? BMW sells a module you replace for the orange display, or you can solder new bulbs onto the old board. As for the buttons, you replace a bulb int he rear of the OBC.
Old 10-27-2003, 03:08 PM
Rainman66's Avatar
I have the same problem and just priced the blub (2 on a circuit board)at the dealer. Cost $48 + tax. Found a used OBC W/ good lights on EBAY for $22. I would confirm the lights are good before bidding and again you are getting a used item so you do take somewhat of a chance.
Doug
Doug Goins
Old 11-05-2003, 01:48 PM
KC Ron Carter's Avatar
some OBC light hints
Change the lights in the light bar
radio shack part# 272-1140 6v bulbs for the DIY.
Here is a procedure on a replacement light bar.
http://www.bavarianautosport.com/Assets/inst_pages/Light_BarComp._Display.pdf
Part Number Description Price
65 81 1 375 461 on board computer (OBC) $24.95
Later,
Old 11-05-2003, 07:24 PM
