Mo money = mo parts
Alignment settings w/M3 Control Arm Bushings
I'm getting ready to refresh my front end. I want to change everything from the strut tower bearings, to the struts, to the control arms and tie rods ends.
I have read that the M3 lower control arm bushings (lollipops) will reduce tramlining - the tendency to follow the ruts in the road. I would love to hear from someone that has installed these busings - did it reduce tramlining? what suspension alignment settings were used? any other front end suggestions?
95 325i w/sport package 85k
Thanks in advance
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-08-2003, 05:21 AM
KUTCH's Avatar
I installed the 95 M3 strut bearing in my 98 328is. Bilstein HD H&R OE sports...align using sport package specs...
Old 10-22-2003, 11:53 AM
mikehd's Avatar
Re: Alignment settings w/M3 Control Arm Bushings
Thanks in advance
I've done this as well. The '95 offset M3 LCA bushes help to increase caster angle. This helps reduce tramline effect. Couple them with '95 M3 Upper Strut Bearings, and I have a great tracking car with 17" M3 alloys, Bilstein Sports & H&R Sports.
The later M3 LCA bushes are not offset, but are solid rubber, so they improve turn in response, but do not help tramlining.
1995 325i Boston Green
Old 10-29-2003, 08:58 PM
Mo money = mo parts
Do you use the M3 suspension settings? or Sport Suspension? Did you also replace your control arms with M3 arms or just the bushings? Thanks.
Greg
Old 10-30-2003, 05:55 PM
mikehd's Avatar
I used 1/16th toe in for the front. Rear is set the same with -0.1deg camber.
Stock control arms. Couldn't see the value in paying for the M3 arms.
Mike
Old 10-30-2003, 06:40 PM
Mo money = mo parts
Don't the M3 strut bearing increase caster by tilting the strut assembly back toward the rear of the car and the LCA bushings increase camber by pusing the bottom of the wheels out? I thought the M3 strut bearing had more of an impact on tramlining than the busings. The increased camber is better for a track car to keep the outter wheel flat during hard cornering. I'm not challenging anything you said, just to understand a little better. Thanks.
This link was informative for me.
http://www.whiteline.com.au/faqsusp01.htm#Castor%20Vs%20camber
Greg
Old 10-31-2003, 09:55 AM
KUTCH's Avatar
GREG,
I installed the 95 M3 strut bearings which induce +3 deg positve castor over the normal ones. total = ~6 deg... no additional camber, I don't track the car...The lolllipops help with castor as well. Picture it like a boomerange pivoting about the center corner, being pushed out by one of the others. In this case pushing the bottom of the strut back (toward ther rear of the car) which adds more castor. this is if you use the offset ones. the normal ones just stiffen things up...
Old 10-31-2003, 11:43 AM
Mo money = mo parts
Kutch,
Thanks. Which lower control arm bushings did you use? The standard 3 series, the 95 M3 offset busings, the 96 M3 bushings, or some other? Thanks again for the informative reply.
PS I just switched to my winter wheel/tire combo - 205/60/15. The tramlining is gone, but it will return with the summer 225/50-16s.
Greg
Old 11-01-2003, 04:37 PM
