BMW Roundel Where is the amp for the stereo located?
Can someone tell me where the amp for the stereo is located. Whoever owned this car in the past butchered the installation. I looked over a wiring schematic and noticed all of the speaker wires come from the amp. I want to re-route these to the new stereo instead of running new wires to the rear of the car. Thanks all!
Old 12-17-2003, 08:56 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
The stock amp is located in the rear trunk on the drivers side right in fromt of the antenna. You will need to remove the inner fender liner to access it. All you need to do is bedn down the clips at the top of the liner and then pull the liner out of the trunk.
Old 12-17-2003, 03:34 PM
Jeez, you guys know every little trick in the book!
Old 12-31-2003, 06:53 AM
