fuel injectors
can i use injectors off an eta engine for an is ???????
i think i have run down the problem on my is to a bad injector, i have a set of good injectors from one of my parts car but its an eta engine....
thanks for the help
Old 12-04-2003, 06:53 PM
The bently manual has a diagram of which fuel injectors fit which engines. The resistance in the injectors themselves are different for each vehicle. The ETS injectors have different resistance than your is.
85 325E, 89 944 S2, 91 mustang, 71 Monte Carlo
Old 12-05-2003, 05:22 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I do not believe that the those injectors will work in an is.
Old 12-05-2003, 08:01 AM
thanks, i thought injectors are relatively interchangealbe, at least that is what i understood from some of the mods people do, like using the mustang injectors and so on
Old 12-05-2003, 08:41 AM
It is possible to interchange some injectors, however it's a matter of getting the right fuel mixture in the cylinder, In the case of the Mustang injectors, you alos have to upgrade the AFM, and tweak the mixture screw a bit to get it to work right.
Old 12-05-2003, 03:43 PM
