Unhappy 89 325i engine quits and then starts
My sons 325i 89 runs great. He goes into a store and back out car starts runs great then he said the guages starting jumping, car bucking, then stalls. few minutes later starts up runs then the same thing. The car does crank great and the battery cables are tight. Any help you can give would be great. Thanx Chris
Raise hell and run naked!!!!!!
Old 02-11-2004, 09:04 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
this could be a bunch of things
have you read the codes off the computer?
Old 02-11-2004, 09:05 AM
starts stops etc.
No I have not ck the codes, where,how,etc. Thanx chris
Old 02-11-2004, 09:11 AM
Check this out...
http://www.pelicanparts.com/bmw/techarticles/JF-Tech/E30_E36_On_Board_Diagnostics%20.htm
Old 02-11-2004, 09:12 AM
find out what codes it shows and ill tell you what is probably causing the problem...
Old 02-11-2004, 09:14 AM
Jared: Thakx for the help. The code comes up 1444 and that means noting wrong with the system. I will have my son do this when it dies and try again. I am thinking maybe fuel pump or fuel pump relay or a possible bad ing. switch. Chris by the way, where is the fuel relay and the fuel pump?
Old 02-11-2004, 09:43 AM
check fuel filter sounds like it may be clogged.
Old 02-11-2004, 09:47 AM
