Step On It!'s Avatar
Red face cassette player keeps switching sides
I still have the original factory head unit in my 92 325is. The cassette player keeps switching from side one to side two.
Any ideas on how to correct this problem short of removal/replacement?
Old 01-15-2004, 10:50 AM
blkongry's Avatar
Oh, what is that wear problem called... something like "capstan tension malfunction"... I can't remember. Anyhow, the problem is that the tensioner that drives the tape has weakened, and the amount of drag it sees is now triggering the auto flip feature of the deck. Now, it could also be that the deck is working fine, but your tape has too much drag in it and that is what is triggering the auto flip. Does it do it on all the tapes you have? If it does, then replacement is probably going to be cheaper than repair.
Old 01-15-2004, 11:07 AM
It does this when I have the adapter running through it (so that I can use my portable cd player). I will try a real cassette to check it out.
Old 01-15-2004, 11:19 AM
blkongry's Avatar
Oh, if it runs with the adapter, then it is definitely the player itself. Hmm, before saying things are worn, things are more likely to be dirty. One doesn't want to 'blow out' electronics components because of static discharge, but you can try getting into the drive from the cassette door with a long handled Q-tip and cleaning the system (with Isopropanol), then adding a little silicone lube in the drive system (don't get it on the tape head though). Don't use WD-40 because it tends to dry out quickly. A silicone lube has more staying power. Good luck.
Old 01-15-2004, 11:25 AM
Do you think usiing the "official" bmw tape cleaning system might work? I think I have it stashed somewhere.
Old 01-15-2004, 01:13 PM
blkongry's Avatar
Yep... a cleaning tape should help.
Old 01-15-2004, 03:10 PM
Do you guys know anything about my CD player skipping in a 1999 328iC
Old 01-17-2004, 01:33 PM
I have no idea.
Old 01-19-2004, 08:45 AM
supertack's Avatar
I don't think that auto-reverse malfunction via the adapter is solely a problem with your unit, or any other E36 unit for that matter. I had the same problem with my Volvo 760 turbo when using the tape adapter. I think these factory units get 'confused' when there is the presence of another head as opposed to movable tape. Cleaning the unit head & the adapter head always worked for mine.
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 01-19-2004, 08:53 AM
blkongry's Avatar
Depends on how it is skipping. The predominant reason for skipping is that the rubber hub which the CD 'floats' on has dried or hardened up... it causes the CD to move out of alignment and therefore allows for skipping. This usually happens to older equipment, but with having a 1999, this shouldn't be your problem... other than just the cold weather causing the system to be a little more sensitive than usual.
Can you describe the skipping? Meaning, is it a sporadic... or constant... or different between CDs? Is your system just really sensitive to any outside vibration? More clarification can help pinpoint the problem area.
Old 01-19-2004, 08:56 AM
