Question about the Pelican Parts Clutch Super Kit
I have a few questions on this product:
1. Does this kit include the Sach's Heavy Duty clutch, or just the normal one? And, if not - do they have the Sach's HD clutch kit?
2. I have a 1988 Super Eta. I will also be making the certain mods to turn it into a 2.7i I Engine Stroker. My question is, will I use the 325i/is/iC (1987-91) kit or the 325/e/es (1984-86) kit?
If anyone could help me out, that'd be great.
-Sean
Old 02-29-2004, 09:01 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
The super kits only include the OE clutch disc, which would be the normal one.
I cant tell you what clutch kit to use unless I know what block you are sing for the build.
Old 03-01-2004, 07:29 AM
Since the block of the Super ETA is the ETA block, or so I thought, that's what I will be using.
I still have a bit more research to do onthe engine part of this.
Old 03-01-2004, 08:35 AM
If it's an ETA block, you'll need to use the kit for the 325e...
Old 03-01-2004, 03:44 PM
So, basically the years don't matter?
I thougth about it, and have decided to just go ahead and get the OEM one. Took some talkin from someone to get me to realize the HD was overkill.
Old 03-01-2004, 03:56 PM
It is overkill.
The years do matter. like i said, if it's a 325e, you'll need to use a 325e kit..
Old 03-01-2004, 03:57 PM
Thanks for your help Jared, I now have everything figured out.
Thanks again!
- Sean
Old 03-01-2004, 04:39 PM
Still haven't worked up the cash to buy this, but hopefully soon.
I got a few more questions:
Does the kit include the shifter shaft seal and output shaft seal? I'm guessing it does, cause it says it includes all tranny seals.
Thanks!
Old 03-17-2004, 06:57 PM
