Driver's side Window Dead
I have a 1996 328is and today I noticed that when shutting the driver side door the window wouldn't go up as is supposed to. Well I then tried to roll the window down and up and I hear a click but the window is dead.
Checked the fuses and they are all ok.
The right side passenger window works fine.
Could it be the window motor / regulator ? what is the diff btw the 2?
How much is it roughly and is installation hard?
Old 03-11-2004, 12:02 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Sounds like the regulator may have slipped a track.. You might want to rtemove the door panel and check that the window regulator frame is ok... Sometimes, you can just pop it back into place..
Old 03-11-2004, 01:48 PM
Diffently sounds like your sliders broke on your regulator>>you can easily replace the sliders>>but if the regulator is bent it also will have to be replaced>>Not hard either but if its never been changed you have to drill out the rivets>>and replace with bolts. Can you hear the motor working???
Old 03-11-2004, 06:04 PM
you know, im sort of having the same problem, except my window will go down when i push down on it a little, but to come back up i have to manually lift it up, the motor is working and nothing seems to be loose or broken?
Mike D
Old 03-12-2004, 07:51 AM
hmmmmm.....u mean u have 2 lift it by hand OR keep hitting the button 2 make it come up?
Old 03-13-2004, 11:32 AM
Cowboy,
i have to lift it by hand to bring it back up, like i said the motor runs but wont lift
Mike D
Old 03-15-2004, 08:26 AM
then you have the same problem>>ur sliders are broke and the mounts are UNDER the regulator mounts>>pull the door panel & check the regulator>>if its not bent replace the white slider peices>>the new ones come with locking pins>>dont remove the pins>>slide them into the track>>with grease>>then snap the regulator mounts into them>>i use a small pair of channel locks to snap them on>>if the regulator looks bent in any way>>replace it or it will keep popping off>>might even break the glass
Old 03-15-2004, 04:31 PM
