Abs Quick Question
Can i disengage my abs? how? is it safe?
Old 04-08-2004, 12:31 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Why exactly do you want to do this?
just want to check if the abs is the one that's making noise before the car stops
Old 04-08-2004, 12:33 PM
jase007's Avatar
The only noise you'll hear from the ABS is (on LHD cars) the pump cycling behind the passenger right side kick panel when the ABS is engaged. Here is a good site to explain the system basics. How Stuff Works.
ABS sensors in the hubs simply read the gap in the ABS toothed ring that is integrated in the outer CV-joint / hubs. On my car (iX) the four ABS rings are part of the outer CV-joint on each axle half-shaft. Not sure what the E30 2wd front ABS ring setup is.
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 04-13-2004, 06:33 AM
