tachometer/mpg gauges arent working
I own a 1989 BMW 325i and the tachometer is not working. I dont know if its a fuse or if its something in the wireing, or if a sensor went out. The fuses seem to be in all good shape but, the last owner seems to have lost the cover and i dont know which fuse is what. so if you have any info. I could use,please post. thank you much.
This happened to me and it turned out to be a bad Service Indicator board. I replaced it last Friday night and it has been working fine ever since. From my web search, this is a general trouble point with the car.
Here is a link to one place that had a good description of the procedure: http://e30m3performance.com/maintenance/SI_Board/SI_Board.htm The real problem are the batteries. You can change just the batteries if you are handy with a soldering iron (I'm not) or get a new board. I bought a new rebuilt board for $105.00 at a local shop. If you are careful and willing to finaggle a little bit, you don't have to remove the steering wheel. My car has an airbag and I didn't want to mess with removing it. Rich |
Rich:
Email me off board for more info. Jason |
Word of warning... I had the same instruments not working and I relplaced the SI board... no change.
I still think there must be a way to test for a signal at the pick-up sensor, wherever that may be... but no one has ever been able to shed any light on it for me. I hate blindly replacing parts... just throwing parts at something is never the best way to work. |
I've heard that sometimes removing the sensors and cleaning them can make the light go out, although I dont really know. You may want to do a search on this...
| All times are GMT -8. The time now is 06:55 PM. |
