E30 wheel fitment question
new to board and E30's this has probably been asked before but i didnt know how to search for it.
will 97-98 M3 wheels (24m?) fit my 91 325 iC?
thanks
Old 03-12-2004, 08:09 PM
Send a message via AIM to wludavid
To quote jim72911t:
E30 325s and 325is had 14 x 6 or 14 x 6.5 four bolt wheels (4 x 100) with either a 30mm (basketweave) or 35mm (bottlecap) offset.
E30 325ix's had 15 x 7 FOUR bolt basketweave wheels (4 x 100) with a 41mm offset. These can be used on other four bolt E30s with 15mm spacers.
ROW E30s 325s (325i Sports, I believe) were available with a 15 x 7 four bolt basketweave wheel with a 25mm offset. These can be used on other E30s with no modifications. However, they are rare as hen's teeth so if anybody finds a set they should send them directly to me in exchange for this info!
E30 M3s had five bolt (5 x 100) 15 x 7 or (in Europe) 16 x 7.5 basketweaves with a 20mm offset. M3 apps only. (actually, they fit some 5 series cars, but we won't get into that here.)
E36 M3s had five bolt (5 x 100) 17 x 7.5 or 17 x 8.5 wheels with a 41mm offset. These can be used on E30 M3s with spacers.
The 325iC's probably are the same as the 325i, so I would look for a 15" wheel with a 25-35mm offset, depending on the width of the wheel. THe 97-98 M3 are the E36 body.
Old 03-12-2004, 11:51 PM
thanks for the wheel info!! so if i want a more
modern look on this car what are some suggestions? say in 16 0r 17 in?
Old 03-13-2004, 12:08 AM
15-17" should work, depending on if you've lowered the suspension. Keep in mind that the larger the wheel, the heavier it is, and the more energy it takes to accelerate it.
1987 325 eta
Old 03-13-2004, 12:16 AM
thanks, not a hot rod, but want more modern look
what are some of the better looking wheels for the E30's, mine is a white convert w/ the small 14 in basket weave wheels.
Old 03-13-2004, 12:43 AM
carolinus's Avatar
Alpina wheels are great. Look em up!
I am blessed/cursed with these cars:
BMW 318iS 1991
BMW 325iS 1988
Volvo 740 Turbo Wagon 1992
Quote of the week:
"This chemical is known to cause Birth Defects in California."
Poor Californians, they are always getting the short end of it, and now this?
Old 03-13-2004, 05:57 PM
thanks, saw the alpina, to many spokes for me
i am currently looking for the euro 15x7 on 4 mentioned in this thread. any ideas where to look?
Old 03-14-2004, 07:55 AM
The 4-bolt 325ix wheels are a lot more common and keep with the stock bmw look. I just saw a set on ebay last week. I thought about buying them because they were a good deal, but they cease to be such a good deal when you factor in the $100+ you would spend on spacers you would need to get the proper offset.
Have you looked on TireRack.com? There are few nice looking wheels there.
1987 325 eta
Old 03-14-2004, 06:04 PM
the use of spacers bothers me a little. but the euro 15's sound promising
any photos of the 15x7 on the 325?
Old 03-14-2004, 06:32 PM
Send a message via AIM to jimsill
i have 15x7 basketweaves on my car, ill try to post a pic. They are not genuine BMW, the are RONAL ACT LS wheels, available at www.ronalusa.com Gorgeous and affordable. I found mine online mint used with good tires for 500 shipped!!
Old 03-22-2004, 01:05 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
To answe this in a nutshell, they wont fit because the E30 is a 4 lug setup, whereas the M wheels have a 5 lug setup.
Old 03-22-2004, 03:47 PM
You can also use the Kosei 15x7 wheels which are light. TireRack sells them for $129 each. I have them on my car with 205/50/15's.
Rich
2004 GT-3
1969 911E
1988 944 Turbo
1990 BMW 325i
2001 BMW Z3
Old 04-12-2004, 04:15 PM
jase007's Avatar
David's mentioning the iX wheels as an option is a good one but also add in $100 + to true up the wheels. For whatever reason, the BBS supplied OEM BMW 15 x7s (4 bolt 100mm) seem to go out of round pretty easily. I refinished and trued up mine several years ago for around $125 each. They probably need it again.
I have been looking at those Kosei racers (nice and light) in 16 x7. I wouldn't suggest getting a 17" wheel unless you have uprated suspension / brakes to handle the additional rotating mass. I am sure peolple here have 17" wheels on their E30s but IMHO I think they are too much for the car. Tirerack, discount tires and discount tires direct all have pretty good wheel / tire online selections.
Jason
Jason
'58 -'76 P-cars
SSPI ~ JScott Racing
Old 04-13-2004, 06:08 AM
I was under the impression that the iX wheels wont fit without spacers...
Old 04-14-2004, 07:13 AM
