backfiring-hesitation problem
i have backfiring-or popback kind of problem when i try to take off quickly or at idle i hit the gas pedal real fast but if i take off slowly or rev up the engine at idle slowly it doesn't do it.anybody seen this problem on a 92-325i 5 speed. thanks
Have you checked the follwoing things?
vacuum leaks O2 sensor spark plugs fuel filter This could be a variety of different things. Have you run the codes on the car.. If not.. read this...http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm |
I had the exact same symptoms one time after washing my girlfirend's 318. I did a light wash on the engine, but it turned out I got water somewhere it shouldn't have been, and that caused the misfiring. I took it to a shop where they cleaned it up for $40. I don't know where the water ended up being, but it seemed like an easy fix. Have you exposed the engine compartment to water recently?
| All times are GMT -8. The time now is 06:20 PM. |
