Exclamation backfiring-hesitation problem
i have backfiring-or popback kind of problem when i try to take off quickly or at idle i hit the gas pedal real fast but if i take off slowly or rev up the engine at idle slowly it doesn't do it.anybody seen this problem on a 92-325i 5 speed. thanks
Old 04-16-2004, 06:40 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Have you checked the follwoing things?
vacuum leaks
O2 sensor
spark plugs
fuel filter
This could be a variety of different things.
Have you run the codes on the car..
If not.. read this...http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
Old 04-19-2004, 06:58 AM
blkongry's Avatar
I had the exact same symptoms one time after washing my girlfirend's 318. I did a light wash on the engine, but it turned out I got water somewhere it shouldn't have been, and that caused the misfiring. I took it to a shop where they cleaned it up for $40. I don't know where the water ended up being, but it seemed like an easy fix. Have you exposed the engine compartment to water recently?
Old 04-19-2004, 09:57 AM
