Running Rich
Hi
I just recently purchased a 93 325i and have been having a few problems.
The car seems to run fine when cold but when at full temperature there seems to be a lack of power and the car seems to hesitate.
I got the air filter,plugs,oil and oil filter changed when i first got the car at a garage...anyway,ive just checked the sparkplugs which have only done a few hundred miles and theyre black with soot, im not very mechanically minded but even i know this means the car is running way to rich.
Any ideas whats making it run rich? After reading many posts on the forum i get the idea it might be the O2 sensor?
But would this also not effect the car at idle as the car idles fine?
any suggestions most welcome
Old 05-09-2004, 11:27 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Sounds like the O2 Sensor. How many miles are on the car?
Old 05-10-2004, 07:20 AM
Thanks for the rely....there are 99k on the clock.
Old 05-10-2004, 08:51 AM
SOunds as though the O2 Sensor should be changed at this point
Old 05-10-2004, 08:53 AM
blkongry's Avatar
Yeah, I'm thinking O2 sensor also. The O2 sensors don't usually 'go bad' per say, but rather they get coated and clogged, reducing their ability to read the changing exhaust mix. This is something that probably wouldn't even be noticed at idle, but would be noticed under load and with soot forming at the exhaust (not to mention sooty plugs).
Old 05-10-2004, 08:59 AM
supertack's Avatar
For all us 'stu-nods' out there, where is the O2 sensor located, & how would you go about changing it out?
Every Boy Becomes A Man. A Fortunate Few Reverse The Process.
97 328is
Black on Black 5 speed
Sport Package, Short Arm Intake with ABS Molded Heat Shield, Custom Mounted Front Strut Bar, Elevated Clutch Stop, Polished Aluminum Roundel Shifter, AC Schnitzer Aluminum Pedal Set, Chrome Instrument Cluster Rings & Carbon Fiber Bezel, Crystal Clear Corners, OEM Clear Tail & Side Lights, Scalloped Headlight Trim, Custom 'is' Grill Badge, Alpine C43 Stereo Upgrade, Front Bumper Filler
Old 05-10-2004, 10:49 AM
The O2 Sensor is typically located in the exhaust manifold down near the bottom of the car.
Old 05-10-2004, 11:13 AM
Cheers for the advice
I think ill get the local garage to replace it for me as ill probably make a hash of it. I think you need a special tool to do the job aswell.
Old 05-10-2004, 01:23 PM
Do it yourself, it's beyond easy... Check this out...
http://www.pelicanparts.com/bmw/techarticles/E30-O2_Sensor/E30-O2_Sensor.htm
Old 05-10-2004, 03:49 PM
Thanks for the replys guys....well, i changed the 02 sensor today,fairly easy job and what a difference
Car now runs great, no more hesitating,and a lot more responsive and willing to rev right up to the red line.
Me a happy bunny.
Old 05-13-2004, 10:54 AM
