Key won't turn
Hi,
The ingition on my friends 1988 325i's car won't turn to start the car. It will turn a bit (just enough to get the warning lights on the display to light, sometimes) but not enough to crank the engine. What is causing this problem?? The car is stuck in a mall parking lot and some kind of solution would be appreciated.
Thanks.
Old 08-05-2003, 10:40 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I had this same problem with my car and it turned out to be a broken ignition cylinder. You may have to do what I did and drill the cylinder out enough to withdraw the remnants, then replace the cylinder. It's not an easy job unfortunately.
Old 08-06-2003, 08:59 AM
Thanks for the response, Jared. Is there any other possibility that I should explore?
Old 08-06-2003, 10:44 AM
I cant think of any. Sounds like the igntion cylinder is wasted.
Old 08-06-2003, 10:45 AM
Jared,
Could you please mail me the part number and/or link and some basic instructions on how to replace the cylinder? I'd really appreciate it. My email address is: sagesse2002@lycos.com
Thanks in advance!
Old 08-25-2003, 09:11 AM
It would be better for you to give me a call, as there is a lot of work involved here and I think it would be easier to go over it over the phone.
1-888-280-7799 ex. 259
Old 08-25-2003, 10:09 AM
Thanks, I'll give you a call tomorrow.
Old 08-25-2003, 07:25 PM
Greetings,
Any resolution on this? How many dollars to fix? I'm having the same problem
-Dave
Old 05-16-2004, 10:59 AM
