removing rear springs
can someone give me a tip to remove the stock rear springS? im replacing them with H&R sports.
Old 05-21-2004, 01:20 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
You'll need to unbolt the rear shocks at the bottom, unbolt the sway bar links, loosen the muffler straps and allow it to lower down, Then remove the bolt that secures the differential to the car and wedge the differential down. This porvide enoguh clearance to remove the springs...
Read this... step by step...
http://www.pelicanparts.com/bmw/techarticles/E30-Rear_Suspen/E30-Rear_Suspen.htm
Old 05-21-2004, 01:43 PM
