Send a message via Yahoo to cessnapilot
Angry 99 M3 Down on Power, BMW Code Scaner Wanted
This is my first real problem with my 99 M3. It is down on power as I said. I bet my 98 Audi (190hp) would take it in a drag race right now. When I get to 5000 RPM it starts drop off. Almost like it is Leaning out. I do have a check engine light that set after I had a rather large crack form in the Boot that ties the AMM to the TB. That has been fixed. I just replaced the plugs with a set of Bosch Platinum 4's. The Plugs I removed had alot of miles on them and they were Ashen White in color. I was thinking it was caused by my vac leak (It was there for sometime before it got to the point of setting the light). I have put about 100 miles on the new plugs and they look ok so far. My car has 110,000 miles on it and I have no real service history. I was think it could need a fuel fliter as I don't know when it was last (or ever) changed. I have pulled my M off the road till this is worked out (Back in the Audi, Winter car).
I am also looking for an OBD2 scan tool. I had an Auto Xray and liked it very much but one day it just stopped working. I would like to find something that can pull all the data from the BMW's ECU (fault codes, Airbag and so on). I dont want to pay more for the tool then I did for the car. I have been looking online and it looks like I am going to need to buy an OBD2 tool and the airbag tool as well. Yesterday the Airbag light came on (oh happy day) .
Any help on this would be great.
Save my M from being put to bed in Sept rather then Nov.
Spandex, it is a privledge not a right!
Gravity, it is not just a good idea it is the LAW!!!
1999 BMW M3 Convertible
1998 AUDI A4 2.8 Quattro
1999 Jeep Grand Cherokee Limited
1986 Ford F-250HD
1975 Pontiac GrandVille
1955 Buick Special
Old 09-18-2006, 05:26 PM
Jeron's Avatar
I have the Autoenginuity tool. They just released a new version that will reset airbags and pull BMW special codes but it is an extra $225-ish on top of the base $250-ish..
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-19-2006, 07:00 AM
So it is 500$ but it does everything. Can it also do standard OBD2 stuff on other cars? How do you like yours?
1986 Ford F-250HD
1955 Buick Special
Old 09-19-2006, 04:13 PM
Jeron's Avatar
You should check out the website autoenginuity.com I don't want to give and misinformation.
I use it to pull codes, log OBD data during races (like speed and RPM), check coolant temp and therefore the proper function of the cooling system.
It has a speed tracer program that is supposed measure hp and acceleration but I haven't used it yet.
It used to take a long time to connect but that has gotten better, however it still takes a short while to connect.
I bought the PC and PPC version. You need a PPC with a serial cable or maybe bluetooth to make it work.
Old 09-20-2006, 06:54 AM
Author of "101 Projects"
Wayne 962's Avatar
Yes, that is the best tool for the job. Here it is in our catalog:
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=BE36&section=FULful&page=6&bookmark=37&part_number=AE-ST05
-Wayne
Old 09-20-2006, 11:21 AM
Update:
I changed out the Fuel Flitter and did an oil change using Moble 1 Full Synthetic long life oil. It seems to have helped. I have got back my mid range power. It still is not completely where I feel it should be but it is better.
I am going to order the OBD2 code software you guys talked about. It is going to be a bit before I get it in my hands but it looks like the best one for me.
Wayne in a week or so I am going to order your book. It looks like it could be quite a help.
Thanks for all the info guys.
1986 Ford F-250HD
1955 Buick Special
Old 09-25-2006, 01:20 PM
