Exclamation Starts, then stalls
As the subject states, my 1986 325es starts...then stalls. When it starts up, it'll rev for 3 or so seconds and then die. It's weird because after each stall, it won't start up for another 20-30 minutes. I just CAN'T get my car to idle AT ALL! What can be the culprit? Any suggestions will help me.
Old 07-16-2004, 02:29 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I suppose I would first need to get a little background info on what has been done to the car.
Have you checked the fuel system?
Stalling can sometimes be caused by clogged fuel filters and fuel injectors.
My first suggestion, however would be to run the codes on the car and see if that gives you any clues. http://www.pelicanparts.com/bmw/techarticles/Mult-Code_Reading/Mult-Code_Reading.htm
Typically, 90% of the time, idle issues are caused by vacuum leaks in the fuel injection system. I would inspect and replace any hoses that are suspect or are cracked. This includes also the boot from the air flow meter to the throttle body and the valve cover gasket.
Old 07-16-2004, 10:55 AM
Here's a background of my car's current condition:
Fuel Pressure: ~45psi
Main/Fuel Relays are good
Ignition system checks out as healthy
No visual signs of cracked/worn vacuum hoses or air boot
Can't use the carb cleaner trick to inspect for leaks
Fuel Injectors and cold start valve all jet
Haven't attempted the code readout yet, but other than that...is there anything else I should look at? Can the culprit be related to the fuel return pressure?
Old 07-17-2004, 01:01 AM
