-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Passenger Window Not Working (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/171299-passenger-window-not-working.html)
GWAPITO69 07-07-2004 12:26 PM
my passenger window is not working. when i press on the button the lights would dim and the window will not roll down or up. i tried switching the buttons from my driver side window but still not working. i opened the side panel and tried press the window roll up and down button but still not working i just make the motor hot.. please help...... thanks in advance:(
Jared at Pelican Parts 07-07-2004 12:32 PM
Sounds like the motor may be shot. Is the linkage free? Sometimes, cleaning up the linkage can free things up.
wludavid 07-07-2004 01:55 PM
Try unplugging the wiring harness that goes directly to the window motor and apply 12 volts of both polarities. That way you can determine if the motor itself is shot. It's the most expensive part, so it's good to find that out early.
