Passenger Window Not Working
my passenger window is not working. when i press on the button the lights would dim and the window will not roll down or up. i tried switching the buttons from my driver side window but still not working. i opened the side panel and tried press the window roll up and down button but still not working i just make the motor hot.. please help...... thanks in advance
Old 07-07-2004, 12:26 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Sounds like the motor may be shot. Is the linkage free? Sometimes, cleaning up the linkage can free things up.
Old 07-07-2004, 12:32 PM
Send a message via AIM to wludavid
Try unplugging the wiring harness that goes directly to the window motor and apply 12 volts of both polarities. That way you can determine if the motor itself is shot. It's the most expensive part, so it's good to find that out early.
1987 325 eta
Old 07-07-2004, 01:55 PM
