-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Tapping Noise in Head (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/172103-tapping-noise-head.html)
patrickbmwm3 07-12-2004 04:52 PM
I have a 93 325i (M50) motor which appears to have a tapping noise coming from the head. The sound or tapping is relative to engine speed. From much thought, I have theorized that a lifter is stuck or a valve spring has failed. Could this be a result from such an event?:confused:
The car runs great.:)
Thanks for any input.
Patrick in Atlanta.
kingnine 07-12-2004 06:41 PM
Before you consider the worst, check to make sure your spark plugs are tight first. A loose plug will sound just like a failed lifter or a flat cam lobe on these engines.
jonmatar 07-12-2004 07:24 PM
just out of curiosity..what grade of gas are you useing?
patrickbmwm3 07-13-2004 04:29 AM
I am using 93 octane.
Appreciate the comment about the plugs, I'll check them. I was going to pull the cover this weekend to look for anything suspect.
jonmatar 07-13-2004 07:16 PM
well that definatly rules out detination lol...just curious becuase i put 87 in my car by accident and it was making quite a bit of noise..good luck!
patrickbmwm3 07-14-2004 04:34 PM
Kingnine....Your my HERO! Number 1 plug was 1/2 turn loose. I tightened it down and no more noise!!! How the heck does a loose plug make that noise?:confused:
kingnine 07-14-2004 08:06 PM
The noise is from the compression wave in the cylinder escaping past the loose threads during combustion. Glad I could help.
Dave at Pelican Parts 07-15-2004 07:24 AM
If you let it go for a long time, it will actually erode the aluminum in the head... Not fun!! Glad you caught it before it did.
--DD
patrickbmwm3 07-15-2004 11:10 AM
Obviously, Me too!
