I have a 93 325i (M50) motor which appears to have a tapping noise coming from the head. The sound or tapping is relative to engine speed. From much thought, I have theorized that a lifter is stuck or a valve spring has failed. Could this be a result from such an event?
The car runs great. Thanks for any input. Patrick in Atlanta. |
Before you consider the worst, check to make sure your spark plugs are tight first. A loose plug will sound just like a failed lifter or a flat cam lobe on these engines.
just out of curiosity..what grade of gas are you useing?
1995 325i K&N air filter, clear corners and a lota fun! |
I am using 93 octane.
Appreciate the comment about the plugs, I'll check them. I was going to pull the cover this weekend to look for anything suspect.
well that definatly rules out detination lol...just curious becuase i put 87 in my car by accident and it was making quite a bit of noise..good luck!
Kingnine....Your my HERO! Number 1 plug was 1/2 turn loose. I tightened it down and no more noise!!! How the heck does a loose plug make that noise?
The noise is from the compression wave in the cylinder escaping past the loose threads during combustion. Glad I could help.
914 Geek
If you let it go for a long time, it will actually erode the aluminum in the head... Not fun!! Glad you caught it before it did.
--DD
Pelican Parts 914 Tech Support A few pics of my car: http://www.pelicanparts.com/gallery/Dave_Darling |
Obviously, Me too!
